Upcoming Events for the Next 120 Day(s)
Results 1 to 15 of 16
Thread: Mystery wheels
    Jd110's Avatar
    Jd110 is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2015
    Idaho
    741
    Mystery wheels
    Found a pair these wheels, but now Iím not sure what they where for. Any ideas?
    Jd110's Avatar
    Aug 2015
    Idaho
    741
    Suzuki
    Apr 2012
    MI, USA
    3,645
    Nice nail and washer to hold the hub/wheel on lol. If the machine runs and is rode at all, I'd suggest getting the axle nut or your hub(s) will wear out fairly quick from being loose.
    Jd110's Avatar
    Aug 2015
    Idaho
    741
    Iím sure itís been ed. If you think thatís nice, then youíll like this cardboard/shirt cuff gasket. Lol
    I grabbed it to sell the seat and use the wheels. From the picture, I was hoping the wheels were Honda, so I could use them on the 350.
    Apr 2012
    MI, USA
    3,645
    Haha, now that's priceless, I guess they did that from the cereal box gasket idea. I've made my own gasket before for a clark gas tank, was only a temp solution but I cut a gasket out of rubber roofing, found out rubber roofing is not gas safe, it swells up a lot, but it worked till I had to put more gas in it.
    Anyway, Honda, Suzuki, Yamaha, doesn't really matter for function of the rim, you just need to match the bolt pattern and make sure the offset clears like the exhaust and such. Also rear hubs interchange quite often to other brands, like Tri-z/blaster hubs fits on one of the Honda axles I tried it on, I think it was a 84 200ES axle.
    Typical Honda bolt pattern is 4x110mm for the rear, the way you measure it is across the studs (furthest ones) center to center (also can do like left to left, just use the same side of the stud/hole for start & end point measurement). Most people don't have tape measures that do cm/mm so 110mm = 4.331in or about 4 5/16in
    For $50 I'd pick machines like that up all day long =).
    Jd110's Avatar
    Aug 2015
    Idaho
    741
    Itís definitely the most fun or funnest looking machine I own. Came from California. Hehehe ;()
    Iím going to look at these, soon:
    They are advertised as 200x wheels. He wasnít sure if they are 8Ē or 9Ē. Itís an hour an a half away, but for $100, I may be able use them. I think the valve stem is in the wrong spot for 9Ē, though.
    Apr 2012
    MI, USA
    3,645
    Kind of looks like ATC250R rims, I sold a front gold rim for like $80 not too long ago from an 86. Sold the hub for $100-125 too.
    Jd110's Avatar
    Aug 2015
    Idaho
    741
    Mystery wheels
    If youíre thinking Ď83-84 atc250r from what I can tell, you might be right.
    Apr 2012
    MI, USA
    3,645
    No clue on the year, just know the 250r front hub and rims are gold, not sure about rear hubs. The 200x had silver rims, so clearly not stock 200x wheels lol. Pretty sure the 200x uses 4x110 bolt pattern for the rear tires, so these should get what you need.
    Those are some different looking hubs
    Apr 2012
    MI, USA
    3,645
    Yea they are. Suzuki ran gold rims fairly commonly from what I've seen, so maybe the hubs aren't Honda? Not too many options for front hubs though that look like that.
    Jd110's Avatar
    Aug 2015
    Idaho
    741
    Mystery wheels
    Buying this stuff in person, is about as much fun as using itófor me anyway.
    Turned out he grew up with the guy that sold me the 82 250. Gave me some extra stuff and showed me his 84 250r with a 400. Had reverse, electric start and the 400 swing arm. Super cool!! couple 83-84 250r air boxes and an 85 200x right foot peg.
    Apr 2014
    Edmond, KS
    1,738
    No pictures of the 250R with the 400? I'd love to see some pictures of it.
    Jd110's Avatar
    Aug 2015
    Idaho
    741
    Nope. I wouldnít do that. But, if he offered and gave me permission, Iíd love to share it with you.
    First thing he said was it was a ďb**chĒ, followed by, its a ltz. I said ďSuzuki?Ē He shrugged and told me Kawasaki made them, also. It had the entire rear end from the ltz.
    Told me he had it at St. Anthony last week.
    Jd110's Avatar
    Aug 2015
    Idaho
    741
    350, I talked to him and itís no problem.
    He mentioned again what a royal pain it was. Told me he started it, only because he had the parts. Also said heís glad he did because itís a ďriot to rideĒ.
