Results 1 to 15 of 21
Thread: 200x questions
    Jul 2011
    Mid South
    98
    200x questions
    I have been assembling parts to restore this 200x frame and noticed the bottom triple tree doesn’t have the holes for a headlight mounting bracket and the front fender is different also. Now my maier 200x front fender won’t fit and I am wondering if I have 200x forks or something else.
    Attached Thumbnails Attached Thumbnails 411C2334-44A7-4B57-BBF2-CDBFECC620FE.jpg   E7A4DAF0-4250-4979-8BFD-09057B60589B.jpg   EFAA7EFE-07FD-49E1-952F-B621B28C536B.jpg   91589771-2A52-47E2-8303-71D4B4B09C93.jpg
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    Pekin IL
    529
    Looks like a 250R front fender. Is that a x next to it in the picture, how does a compare that one?
    Sent from my moto x4 using Tapatalk
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Trikefest 2012,13,14,15
    Aug 2016
    East of Worcester ma
    1,328
    86/87 200x triple tree... and forks. That I know. But that’s all I got for ya.
    Shep
    Jul 2011
    Mid South
    98
    The one beside it is a stock 85 200x with a blue rear shock.It has a stock wide shovel front fender but it is vented in the back. I think this frame is an 83 or 84 due to the red rear shock.
    Will I have to get an 86-87 fork rebuild kit for the front shocks or are they the same as 83-85.
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    Aug 2016
    1,328
    Same basically as 83-85——just use care when removing/installing the top fork caps their (aluminum).
    Shep
    Jun 2015
    stonecreek ohio usa
    654
    Is that a 350x front fender? Hard to see on my phone
    Jul 2011
    Mid South
    98
    I know the 250r front fender is a direct fit to the first gen 200x but this front fender had the bolt spacing very close together. It may be a 86/87 200x front fender because its white. Unfortunately maier doesn't offer the 86/87 200x front fender in stealth black anymore.
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    Manheim, PA
    5,753
    Get dc plastics to make you one. He repod all tecate fenders for me. 1st ones free too.
    Your triples and fender are 86-87 200x entire front end is. Many different front ends were swapped in the last 30+ years. It's nothing new. 250r fenders look better imo then 83-85 200x.
    Jul 2011
    Mid South
    98
    My other 200x has these rear fenders that always seemed odd. I’m not sure if there repros or what. They look oem except for they are cut back to far under the seat by the kick starter and the fender support bracket is rubbing into them. I thought they might be 250r fenders but there is even the correct spot in the back for the long 200x decal. If I could just find a support bracket that didn’t cut into them. Click image for larger version.
ID:	259941Click image for larger version.
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    The Open Road
    4,729
    I had those exact fenders on the first 200X I ever bought. I never could ID who made them, but they definitely had that same shape around the kicker and they were cut or molded way too short in the front under the seat. Im pretty sure they didn't cover the rubber fuel tank bumpers on the sides like the OEM fenders do. Finish also looked like it was never shiny like current Maier offerings and the OEM fender bracket had almost worn through the fenders where they touched because they don't fit correctly. I'm pretty sure it had a melted spot where it also touched the exhaust pipe. Those fenders were a hot mess from start
    I gave them away because I hated how they were short in the front and all wrong in all the other places
    Pekin IL
    529
    My Maier fenders were like that
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Manheim, PA
    5,753
    That's maiers. You cant use the factory fender brace like that or they melt. You need to cut the circle part off then use a rubber washer and mount them with a screw washer and a bolt. I'll upload my pics later for those who give a crap about not melting fenders again.
    Manheim, PA
    5,753
    here is what you need to do with maier fenders and the stock seat braket so it does not dig into and flop around to melt fenders.
    Pekin IL
    529
    That looks pretty good, nice job.
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    May 2015
    San Diego, CA
    1,743
    You need to part with that 51 and let me run it!
