Results 1 to 3 of 3
Thread: 1981 185S Alternator disassembly: help!!
    Sep 2019
    MO
    36
    Hello again everyone. This little trike is testing my novice mechanical skills. I'm trying to disassemble the left side crank case to replace a gasket (oil leaking through pull start assembly). I've gotten it about as far as I can go, and now need more experienced advice. I've got the nut and washer off the bolt that goes through the alternator, and all 4 8mm bolts that go through the crankcase.
    How do I get the alternator to come loose off the bolt? I'm guessing when I get that to happen, I can remove the crankcase. As always, thanks for your help!
    Sep 2019
    MO
    36
    Here's the picture of where I got stuck.
    6,726
    You need a flywheel puller , go on eBay or amazon and order one .
