Guess I’ll need to figure out the 70. And geez I’m bad at explaining myself but I’ll try again.
I’m planning on replacing of the stock lamps in the headlights with led, also-(If it works). I’ll most likely lose the high beam function, which is fine. I’ll put the 2 led floods (30watts-each) on a separate switch, so I can run all of them together (headlights + floods). With that, it should be around 80w draw versus the 143.5 running high AND low with old oem lamps. More light, less power is the goal.
Edit: Since, I’ve changed my mind about the oem lamps-they’re going bye bye.
