Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: ATC 185s oil bubbling
    Slidell, LA
    4,737
    Quote Originally Posted by delaswim View Post
    Is the circled bolt hole on this diagram the one I'm picturing? I can't tell. If it is, this is just a missing 6mm Allen head bolt?
    https://photos.google.com/photo/AF1Q...34scWy0jBLVwWf
    For those that don’t have a google account we can’t see the photos. In your photo above, like shortline10 said, you are missing the 6mm bolt, buy one from partzilla or ace hardware and install it.
    6,722
    Your missing one of the four valve cover bolts , part number 9 , yes still available from Honda , as for stopping the leak , it might , the valve cover is sealed with hondabond sealant and if that seal is no good then it will leak .
    Install a new bolt and hope for the best .
    Attached Thumbnails Attached Thumbnails B01D689B-780E-4066-8ADE-AB6D3893D7EE.jpg   98EC3715-2ADB-4BCA-A887-7B4F68D4CC30.jpg
    Sep 2019
    MO
    36
    Thanks shortline. I'll source that bolt and hope for the best.
    Apr 2012
    USA
    4,114
    Kind of ironic, the 185s pic from googled linked back a few posts is from my one site xD.
    Also since there's no link to a source to buy the parts, here's the pages directly.
    Bolt: https://www.partzilla.com/product/ho...6d248d08fbe5e8
    Washer: https://www.partzilla.com/product/ho...6d248d08fbe5e8
    The part shortline mentioned isn't quite the right part, it's the keeper bolt for the compression release which is a special bolt, not any bolt will work. The tip is machined thinner to ride in a race on the shaft. The photo was for a 200x which is a bit different.
    Also note, there is 4 larger nuts and 4 smaller bolts that hold the valve cover on. I can see the nuts in the photo but the bolts aren't so easy to see at that angle. Here's that image from my site again as a reference. The photo it's missing two of the large nuts and 4 bolts that hold the valve cover on. The small bolt that is there is the one you're missing.
    Sep 2019
    MO
    36
    Thanks for clarifying that, PS2fixer. I just bought a 5/8 inch 6mm allen bolt and a rubber washer. I backed the rubber washer with a flat washer and tightened it so the rubber compressed a bit. I'm hoping that does the trick.
    I still can't believe someone rode it around with a missing bolt.
