Thread: Yellow Zinc Plating?
    Mar 2019
    Monroe, NC
    16
    Good morning folks! I hope everyone is doing well. Still tinkering with this little 86 125m. The two "fender stay" brackets that bolt to the bottom side of the seat appear to have been yellow zinc plated from the factory.....said finish has now worn down to pretty much nothing. Does anybody have any recommendations on where I could get them re-plated? I've looked around a bit in my local area and nobody seems to do much yellow zinc.
    Jul 2012
    Penfield NY
    660
    Whoever Mike Palmgren at Vintage Motorsports Restoration uses has to be the best Yellow Zinc plating I have seen.
    My coater does it but it never looks as good as the clear zinc coating they do.
    "See, morbid and creepifying, I got no problem with, long as she does it quiet-like. "
    Trikes:
    1982 Honda ATC250R(in process), 1984 Honda ATC110, 1984 Honda 200s, 1985 Kawasaki KLT160(not running...yet)
    Quads:
    1990 Suzuki LT250S, 2013 Suzuki LT-Z400, 2014 Honda TRX450R SE
    May 2015
    San Diego, CA
    1,738
    You may want to consider doing it yourself.
    I've used the Caswell system and the Eastwood system. The Caswell system has blue, yellow, olive chromates...... The entire system is a little costly compared to the Eastwood system but there sure are a lot of fasteners on your 125.
    NEPA
    7,048
    Do it yourself Follow these steps and you will be thrilled..https://www.youtube.com/watch?v=8_e9EAJiiwY&t=2088s
