Results 1 to 2 of 2
Thread: Leaky 185s
    Sep 2019
    MO
    36
    Leaky 185s
    After a lot of hours wrenching on my ATC 185S, the dang left side still leaks. My issue is oil still leaks out the pull start assembly after the engine warms up. When the engine is cool, it stops leaking. I replaced the left side crank case gasket and another smaller O-ring. This didn't have any impact on the oil leak.
    Good news on a separate incident; I plugged my oil bubble with a 6 mm allen bolt and it stops leaking.
    6,722
    Why didn’t you replace the crank seal while you had it apart , also the gear selector shaft seal should be replaced .
