Results 1 to 7 of 7
Thread: 200x to 250r front hub swap spacers?
    Pekin IL
    529
    I swapped a 85r front hub on my 84 200x. I have a bunch of spacers but nothing's labeled and I can't seem to find the right combination to get this tire centered in the brake line up. Anyone know which ones I need to make this work?
    Sent from my moto x4 using Tapatalk
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Trikefest 2012,13,14,15
    House Springs MO
    5,496
    Custom, but your caliper is probably also going to need to be spaced. This isn't a bolt on deal.
    Jul 2011
    Mid South
    98
    The only direct bolt on solution would be the whole 250r front end. Forks, triple tree,and hub. This guy talks about making custom spacers when swapping just the hub. It a 250sx but the same principle.
    https://www.youtube.com/watch?v=uCdiEtjlIXo
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    Pekin IL
    529
    You guys are right, I was so worried about flipping them spacers around wasn't looking at the big picture. The rotors where it needs to be right now and I could cut down some longer spacers to center the tire up, but I don't really want to space the caliper out that far.
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Pekin IL
    529
    I dug up one of xowner old rims thread's, looks like a 2nd gen 200x hub is a direct swap.
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Manheim, PA
    5,759
    I dud the swap ans used all my 200x stuff, it took more engeey6to post this then measuring and tinkering. You can do it, just keep track of the parts.
    Jun 2009
    Leander TX
    2,219
    As I vaguely recall:
    The 1st gen 200X hub is the widest vs 3rd gen R and 350X.
    All 3 have same spacing (rotor flange to wheel flange) on the rotor side and the difference is on the not-rotor side.
    You should be able to use the stock 200X spacer on the rotor side and a custom one on the not-rotor side.
    This is all theory not actually tried by me.
