Results 1 to 3 of 3
Thread: 1981 ATC 110 won't run
    Aug 2019
    WI
    I got a 1981 ATC 110 that won't run. It has spark and I the ignition timing is correct, the carb is new, the valve clearance is perfect, and the exhaust pipe is clear of obstructions. It will occasionally run for a second on carb cleaner but is extremely finicky. There is fuel getting to the carb. We also pulled it behind a truck for 20 minutes and it would occasionally start running and even slack the tow strap but it wouldn't last. The carb has been tuned to every setting imaginable, and I have successfully tuned other Honda three wheelers. Any guesses on what is going on?
    6,807
    Check your compression . If you don’t have a compression checker , place your thumb over the spark plug hole and pull the recoil , you shouldn’t be able to hold your thumb without it leaking air , push hard btw .
    Might need a topend rebuild
    Aug 2019
    WI
    Thanks, that was the problem. There was absolutely no compression.
