Camouflage Painting Tips
The best way to camouflage an object is to match it to the surroundings in which it will be located.
Use colors in the same family that work well together.
Start painting with the lightest color and move to the darkest color.
Take your time! Since there is a lot of overlapping, small mistakes won’t show.
As with any spray paint, use several light coats instead of one heavy coat.
Always read the directions before applying the spray paint.
Stencils:
– Create your own stencils by hand.
– Look to nature; use local tree leaves and branches as your stencils.
These hopes can help you:
http://www.camouflagewebbing.com/pro...great-britain/
there are no secrets to success. it is the result of preparation, hard work, and learning from failure.
- Colin l. Powell
