Thread: Help identifying which model of 3 wheeler I have. Help is appreciated.
    Nov 2019
    Elk Ridge, Utah, United States
    5
    I bought a three wheeler last week the guy told me it was a 1984 200s but I was doing research online and things aren't matching up so I wanted to see what you guys think. It's chain driven with electric start and pull start.Click image for larger version.
ID:	260614Click image for larger version.
ID:	260615Click image for larger version.
ID:	260616Click image for larger version.
    Nov 2019
    5
    I should mention that I did take off the plastics as well as a metal basket on the front.
    San Marcos Ca.
    704
    It's most likely a 1984 ATC 200m .
    * 1970 US90 Red
    * 1985 ATC 200s
    Apr 2012
    USA
    4,114
    You can also use my site below to look up the VIN number on the neck of the frame as well as the engine's serial number which should be near the bottom of the case near the sprocket area.
    http://atvmanual.com/honda/interacti...er-atv-and-atc
    If there's a mix of parts, I have some machines covered in my post detailing year to year differences for different harnesses. If it's a 200m I can look at the harnesses I have on hand so you know if the harness is an 84 vs 85. Might help tell a story on what happened with the machine and what all it's been merged with.
    http://3wheelerworld.com/showthread.php/187317
    Jul 2018
    TN
    1,065
    200cc, Chain drive, electric start & NO transfer case.....that can only be an "M" engine.
