Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, 225DX, trx300
The motor might be on the verge of over heating and just melting it .
Check to see if your exhaust is not plugged up, I had a car with a plugged cat and it did the same thing repeatedly till I opened it up. uhh I meant replaced the cat.
No trike left behind
1983 Ytm 200
1983 Honda 200
1982 Honda 185s
1983 odyssey fl 250
1987 yz 250
It almost looks torn, not melted. Do you have any pictures of it NOT in the bike?
this pictures is of it uninstalled. It was fine when it went on, but after the bike was run and left for a few hours, the hole was present. i tried some epoxy to fill it, but that failed, it started, but had major vacuum leak and idles at about 3/4 throttle. i'll look into the clogged up exhaust, i was with a friend in his 1988 CR-X when the cat go so hot, that it could not flow anything and it shut down the engine because of lack of flow. (we were going faster than the speedometer could register.....)
