Results 1 to 15 of 15
Thread: Kx250 motor into a tecate 3
    vroomy's Avatar
    vroomy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Australia
    174
    Has anyobe here successfully fitted a late model kx250 motor into a tecate 3? Either 85 or the newer 86. Got an 86 atc250r frame i wanted to put a cr motor in but the whole forward kickstart thing, hence lookibg at the tecate idea
    Arizona
    843
    I know Tecates shared the same engine as the KX 250s back in the day, but if you're talking about more recent KX's I can't say. I haven't seen it done. I know people have put modern YZ engines in the Tri-Z. I would think the KX engine could be done, it just depends how much fabrication you're willing to do.
    Las Vegas, NV.
    2,531
    Someone on these boards swapped a newer KDX engine into an '85 Tecate a few years back, if I'm not mistaken.
    vroomy's Avatar
    Australia
    174
    Yeah im looking into doing a 99+ kx motor into an 85 tecate. So far the biggest hurdle seems to be the down tube on the frame will be right in front of the exhaust port? Will obviously need to fab in a Y piece.
    Las Vegas, NV.
    2,531
    Apr 2019
    Greece
    58
    Hello vroomy, alexandros here in Greece did it many years ago but with an 86 tecate frame. So it can be done but your biggest issue is as you said the cradle at the 85 frame will be in the middle of your exhaust so you will have to make it U like the 86.
    http://www.3wheelerworld.com/showthr...ght=Alexandros
    Nov 2019
    Florida
    1,048
    I don't know jack about a tecate (other than they look awesome) I did own a KX250, and all I tell you is they run like a bat outta hell, I miss that bike for sure.
    Good luck, nothing a welder and a die grinder cant fix.
    MrC.
    Williamstown PA
    5,825
    No dirtbike motors had counter balancers but 4 strokes. With out it your gonna vibrate your hands bad. It will turn into a conversational item for your she shed vs a machine your gonna go ride 6 hours on sunday. This is my only warning.
    Just build an 85 tecate motor or blow in a 4 stroke. You will have somthing you can enjoy more then looking at it.
    vroomy's Avatar
    Australia
    174
    Im pretty sure none of the tecate motors had counter balancers anyway, so shouldn't be any different?
    vroomy's Avatar
    Australia
    174
    I know i had tighten evey bolt after a day of riding on my 87, thats if they didnt already fall out lol
    Williamstown PA
    5,825
    if thats your idea of fun then go for it. I'd rather see a LT250r motor in one. Its been done a few times. If your a yard rider then it wont matter.
    Las Vegas, NV.
    2,531
    Quote Originally Posted by vroomy View Post
    Exactly! Only the Tecate 4 motor's had a counter-balancer.
    vroomy's Avatar
    Australia
    174
    "Yard rider" haha. Why would i want more power if i was a yard rider? If thats where i was going to ride i would stick an lt250 motor in because they are so tame
    Some things never change! Old Stool fails again! The Tecates didn't have a counter balance brand new from the factory!
    Sep 2005
    MICHIGAN
    2,027
    You might find more info in here:
    http://www.3wheelerworld.com/showthr...ap-Interchange
    There used to be a picture of a LT250R motor in a tecate frame in there....
    86 T3
    84 T3
    86 KX250
