Results 16 to 30 of 31
Thread: 250sx skinny tire
    Aug 2017
    US
    20
    Quote Originally Posted by sledcrazyinCT View Post
    So the front used the stock hub and brake drum. Did you have to modify the spacers or did the new rim keep everything centered?
    Stock hub no spacers I tried putting on the hub was super close so. I enlarged the bolt holes on the rim just a hair think only two holes. And i mean just a hair thousands.
    Sent from my moto z3 using Tapatalk
    Connecticut
    1,605
    Quote Originally Posted by ChadSaA View Post
    So you didn't have to modify or remove #5 and #7 in the photo below?
Name:	250SX front wheel.jpg
    Aug 2017
    US
    20
    Nope. Not at all.only enlarged the holes on the rim just a hair. Google it there's several pages on it.
    Nov 2019
    Florida
    1,044
    Thank you ChadSaa, for the details on this modification.
    MrC.
    Jul 2020
    TX
    3
    anyone know where i can get a douglas .125 10x5 3.0+2.0 tire right now? Rocky mtn. been on back order for 3 weeks plus.. i'm on hold for that rim / tire... combo.... any advice appreciated... if not the .125 alum. one then what about the 2+3 steel ??
    Apr 2014
    Edmond, KS
    2,535
    Don't feel bad. I have had a pair of rims for my 250ES on order since June. Apparently DWT got shut down HARD.
    Jul 2020
    TX
    3
    that sucks because the web sellers keep saying expected in stock in 7 more days... i wish they would just be upfront and tell me they have not gotten an order in since June and don't know when to expect them... Now i am moving on to steel and can't find them?? plus new question: i know i can use a 10x5 3+2 offset, but would a 10x5 2+3 offset work or will it mess up brake drum? i would like valve stem on opposite side of drum but its not a must.. does the 3 or 2 represent which side the drum MUST go on? thus to keep the drum do i HAVE to use the 3+2 ? i need a tire now and willing to take steel or alum. 2+3 or 3+2 in 10x5
    my email is n214tx@gmail.com
    Feb 2020
    US
    57
    Quote Originally Posted by honda200s View Post
    For all you guys with skinny tire on your 250 SX what exactly did you need. Is it a 350X or 200x rim and hub?
    Matt
    This is an 85 200x front end. Used the shock boots from the sx front end cause they are in better shape. For steering stops I used some big nuts welded to the steering stem housing.
    Sent from my SM-G960U using Tapatalk
    Nov 2019
    Florida
    1,044
    Nice bike agedatc.
    My 85 SX is a wheelie machine, it has the stock front end, did this conversion lengthen the wheel base, or change the wheelie characteristics? more/less wheelie prone?
    I really like the front disc brake option as well.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Apr 2014
    Edmond, KS
    2,535
    My 85 Sx also has a 200X front end. The front disc brake is great. If the wheelbase does change with this, I don't think that it would affect the wheelies much. To change that, the rear end (not really an option here) is the one to change the length on.
    Feb 2020
    US
    57
    Quote Originally Posted by MrConcdid View Post
    Nice bike agedatc.
    MrC.
    Sorry to be a late responder, MrConcdid.
    Front end still comes up with little effort. Didn't even give a thought to the wheelbase. Guess I could measure and compare to stock dimension. Assuming the measurement would be axle to axle?
    Feb 2020
    US
    57
    Quote Originally Posted by agedatc View Post
    Oh and thanks for the compliment on my machine.
    May 2020
    British Columbia
    44
    Would that setup still work on a 110? I’m intrigued now haha. I need new rubber so maybe I can order a different front rim for a skinny tire set up
    Apr 2014
    Edmond, KS
    2,535
    I believe that it would. You'd probably be riding a chopper if you put a 200X front end on your 110. You'd also probably need to buy a steering stem adapter as well. Muthey is the one who's making them these days.
  15. #30
    Nov 2019
    Florida
    1,044
    On a 110, put a 185s 0r 200 shock front end on it.
    not as good as a 200x but a nice improvement over ridge mount.
    MrC.
    My Addiction
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
