Results 1 to 10 of 10
Thread: Best way to dull new shiny plastics? 250R
    Jul 2019
    VA Beach
    63
    Some might stone me for this, but let me say I wish to only dull Maier plastics, not OEM...
    I’ve purchased new Maier rear fender and front fender and I’m not crazy about the high gloss look. Also, the first time I run through some brush or wipe mud off, that new shiny look is going to turn to crappy scratched up look. Plus I’m not flashy, I’d have a tough time choosing between a nice primer gray truck vs a candy apple red truck. Best thing I’ve thought to do is rub them down with some fine grit compound, but didn’t know if anyone knew of an easier way that could produce a more even sheen. Maybe something that could be sprayed on and rinsed off?
    Thanks for any ideas...
    Also, where is the best area to document my 85 250R build? I’ve stripped it down and received frame back from powder coat. The oem swingarm is extended 2.375” and is currently awaiting powder coat.
    - 85 ATC250R
    - 85 ATC350X
    - 87 XR200R
    - 00 XR200R (outfitted with long travel suspension)
    - 05 CRF80F
    - 08 DS250
    Jul 2018
    TN
    1,065
    Just go ride the living shet out of it as it was intended. They'll dull themselves after a couple dozen trails. Mud...briars and low hanging limbs will give the exact 'patina' you're looking for.
    You can wipe the mud off with a dry rag. That'll dull them up pretty quick.
    LOL!!!
    Aug 2016
    East of Worcester ma
    1,328
    I suppose- pumice hand cleaner would do it. (Dull the shine) wipe on rinse off...
    Shep
    Jul 2018
    TN
    1,065
    Might even start with tooth paste. It's easy to go more.....rough trip going back.
    Las Vegas, NV.
    2,452
    Extra fine steel wool.
    Jul 2019
    VA Beach
    63
    25 years ago riding the living sh!t out of it would have been the norm, fast forward to now though and I’m lucky to get out once a month. The whole adulting part of managing a career, family, and house tends to put a kink in my time.
    Gojo might work if not used with much elbow grease, toothpaste wouldn’t be much different than rubbing compound.
    I’ll try to research more, everything I found earlier referred to making them from dull to shiny.
    - 85 ATC250R
    - 85 ATC350X
    - 87 XR200R
    - 05 CRF80F
    - 08 DS250
    Jul 2019
    VA Beach
    63
    That might be the ticket, I’ve actually used that on aluminum wheels to get baked on brake dust off.
    - 85 ATC250R
    - 85 ATC350X
    - 87 XR200R
    - 05 CRF80F
    - 08 DS250
    The Open Road
    4,729
    Rub mud on them really good. Works pretty fast too
    When I was a commercial superintendent, I would rub my shiny new hard hat in the mud so I didn't look like those fancy boys like the project managers and engineers with the super shiny hard hats... That way the leads, Carpenters, other tradesmen would take me more seriously (it works)
    Mar 2017
    Ontario
    46
    400 grit sandpaper and a random orbit sander with a light touch.
    Manheim, PA
    5,756
    you dont need 400 grit...wd40 and a green scotch brite pad.
