Results 1 to 8 of 8
Thread: Big Red one way bearing help
    ATCKevin's Avatar
    ATCKevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2018
    Michigan
    159
    My 85 BR has a nasty noise coming from the right side cover. The starter does clunk and the engine makes a clunking sound when you shut it off. What are the characteristics of a failing or bad one way bearing? Iíve never had to replace one before. Also, do I spend the $90 for oem or is a $25 caltric one all I need? Thanks for the help.
    Sent from my iPad using Tapatalk
    Nov 2019
    Florida
    95
    I associate a clunk with a bad gear tooth or something jamming, I have a one way gear go bad on a honda 300, it made a whirling noise when you shut the engine off.
    I have a BR 200es that sheered a keyway, and that keyway jammed up the rotor gear, all gears were ok, and I replaced the keyway.
    What I am trying to say, is pull the cover, verify the problem before you order parts.
    MrC.
    6,069
    The clutch side bearing is for the kick starter and for deacceleration braking .
    The starter bearing is just for the electric starter , they do make a clunk noise when you turn the motor off and that’s normal .
    We have used both and I’m not sure if it was the wear or bearing Quality but the oem worked great and the aftermarket works ok
    ATCKevin's Avatar
    Apr 2018
    Michigan
    159
    Well guys I tore apart my BR to see what the noise was, wasn't hard to figure out once i got the cover off. It appears that whoever was into this thing before didn't peen the clutch nut back in place. It appears that the nut backed out against the bearing in the cover and took out the bearing. Has anyone ever seen this before?
    Also, since I'm going to be removing the centrifugal clutch, I figured I should atleast inspect the one way bearing since I am right there. The way I understand it, the bearing should only free spin one way and not the other. When I turn the bearing one way, it spins freely. When I spin it the other way, the crankshaft turns with it. Is this the correct function? I've never had any run ins before with the one way bearings in any of my machines so I want to make sure everything is kosher before I button the machine back up. Thanks!
    ATCKevin's Avatar
    Apr 2018
    Michigan
    159
    May 2009
    S.E. Michigan
    1,154
    Your description of how the one-way bearing works is correct. The bearing will be free in one direction, but grab in the other direction.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Nov 2019
    Florida
    95
    There's a phrase that only works in a few conversations
    "peen the clutch nut"
    MrC.
