Thread: New here and I need help!!
    Aug 2018
    Central California
    4
    I recently acquired a 90/110 hp atc trike. Almost complete! I just need some help identifying certain parts like the forks and front huh setup. Click image for larger version.
ID:	261292Click image for larger version.
    6,725
    Front hub looks stock to me with a disk welded to it .
    Triple clamps look like HPATC , forks are possibly 82 ATC250R .
    Awesome score BTW , very rare frame .
    Got a picture of the other side
    Aug 2018
    Central California
    4
    I noticed that it is a stock hub but it’s not welded it’s bolted to that plate. That plate is drilled to fit a 12 inch wheel I think from a bw or tri z. I don’t think they are early 250r forks from the pics I’ve seen online. They look very similar to rd250,350,400 forks. I found a picture of one of their ads and it says 34mm triples fit those three forks. And thank you not bad for 20 bucks!!
    May 2013
    Brownsville, Tn.
    1,271
    Yes definitely a great find @ $20.
    Front hub looks to be aftermarket. Possibly a Dickson but 90/110 stuff. Triples look to be HPATC to match the frame. Odd it has a drum brake set up on the rear.
    Motor looks to have mods as well with allen bolts and crank case breather. I'm with Mike. Lets see pics from the other side. Appears to be an old duner.
    * Nicholson 500 Race Bike *
