Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: What do you call these?
    Mexico
    9,018
    Do any of you know the correct term for this style of grommet? I’d like to buy a few exactly like the one in the photo, but for the life of me I can’t seem to find them on the Internet searching with the key words that come to mind.
    Thanks in advance
    Sulphur Springs,Texas
    1,005
    Stator wire grommet?
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Nov 2015
    Davenport iowa
    1,144
    What is that on? A cable?
    1974 original 90 X 2
    1974 Original 70.
    6,811
    Correct ..... it’s definitely a Grommet
    https://www.ebay.com/itm/Yamaha-DT1-...MAAOxyLVZRX6De
    Mexico
    9,018
    Quote Originally Posted by Aulbaugh View Post
    Yes, on a Trail Tech stator cable. Fits a Tri Z case perfectly and has a decent length of sheath molted onto it.
    Thanks guys!
    Mexico
    9,018
    Found some reproduction rubber for a 250/490 IT which as near as I can figure should fit a YZ or a Tri Z give or take an extra hole.
    Then I started looking for the black plastic sheath that most wiring you see exiting a stater cover pass-through. Once again I can’t seem to find anything, and I know that it’s got to be a commonly available item.
    All that seems to be out there are the braided nylon sheaths. If any of you know how to search for the black plastic, vinyl or whatever it is please let me know.
    Nov 2015
    Davenport iowa
    1,144
    High temperature wire harness tubing
    1974 Original 70.
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    What about using shrink tubing and a hair dryer?? (Frank Zappa)
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    Mexico
    9,018
    Quote Originally Posted by Maico View Post
    I’ve done that on some harnesses, but it’s nowhere near as pretty looking as the original sheath that they use from the factory.
    Mexico
    9,018
    Quote Originally Posted by DAM shop View Post
    Found this seller, thanks!
    https://www.ebay.com/itm/PVC-Tubing-...l/142593392133
    Apr 2012
    USA
    4,129
    I have the high temp soft tubing. DAM shop showed a pic of the same site I used to buy it from, now I buy it direct from the manufacture (around 1500ft min order).
    https://i.gyazo.com/d63309935dcce3af...ecbec55e5b.png
    I have 6mm, 8mm, and 10mm. I've tried other suppliers, but the tubing is always super stiff and not soft like OEM. Only that high gloss tubing even comes close to OEM.
    Here's a link to the store that I posted the link to the image of. Joe (the site owner) seems to be getting rid of the high gloss tubing.
    http://www.cycleterminal.com/sleeve-tubing.html
    I'd advise against heat shrink, most of them are rated for 60-80c for the shrinking temp, so normal usage temp should be lower than that. At least that's my view point on it.
    Mexico
    9,018
    If you're interested in redoing my harness from the stator plate to the first connector shoot me a PM with a price. I'd send you the stock parts as well as Ricky Stator ignition and lighting coils and the rubber grommet I just bought.
    Apr 2012
    USA
    4,129
    Use PS2 - He will make you a very nice harness, he found a great niche to excel in...
    Nov 2019
    Florida
    1,048
    Thing-a-ma-bob, dooma-hickie, watch-a-ma-call-it always worked for my dad.
    MrC.
