Results 1 to 12 of 12
Thread: ATC70 Clark gastank Petcock options?
    Mar 2017
    Chico CA
    119
    broke off the cheap plastic petcock and hoping someone has found a better option? Thinking I might be able to thread a couple of brass npt fittings in there as well.
    Nov 2019
    Florida
    1,048
    I have read the reviews on those tanks, and that is a major failure point on them.
    It may be possible to heat the tank (empty and washed) just enough to soften the plastic and then thread a brass bung into place.
    then you would have a brass fitting to work with after the plastic has cooled.
    I have had very good luck with a heat gun on Honda plastic fenders and PVC pipe.
    MrC.
    6,811
    Someone needs to make them out of billet aluminum . I would be in for a half dozen .
    They all fail eventually , big problem .
    The Open Road
    4,736
    What do they look like?
    if you're serious, text me.... Seriously
    6,811
    Here you go Doug .
    Attached Thumbnails Attached Thumbnails FBD98C0F-F111-489B-832C-D7F78CD3F5A6.jpg
    The Open Road
    4,736
    Here you go Doug .
    That's it? No valve?
    6,811
    Yep that’s it , simple part .
    Bolts to the bottom of the tank and two fat o-rings seal it .
    Problem is , the plastic warps over time and the o-rings can’t seal tightly , or it just cracks near the nipples .
    Mar 2017
    Chico CA
    119
    brand new tank and broke both nipples broke off while removing the fuel line.. Anyone try one of the aftermarket petcocks?
    https://clarkemfg.com/product-catego...arket-petcock/
    6,811
    I don’t see how that style would even work when the original style has 2 holes into the fuel tank for on and reserve .
    https://clarkemfg.com/catalog/motorc...90-02-grooved/
    Attached Thumbnails Attached Thumbnails FC728B20-7EE0-421C-A7B4-72630D9E4FC0.jpg
    The Open Road
    4,736
    Quote Originally Posted by Quinc View Post
    I used that petcock on a early 200X Clarke tank. It hasn't leaked in 5 years that I'm aware of.
    That tank only had one hole though, not like the 70 tank
    Your results may vary, of course. I block sanded the mating surface section of the X tank to make sure it would seal
    Mar 2017
    Chico CA
    119
    I have some aluminum tubing coming from amazon and am going to make my own. I will post pics on how it turns out.
    Slidell, LA
    4,738
    I hate it when it cracks near the nipples!
