neutral/reverse light questions
To start with, the machine im working on is the 1987 250es with a china cdi. If you go back, i have posted about it before. I recently purchased the machine and am trying to make it slightly nicer. Anyway, to make that cdi work, the neutral safety wire had to be directly grounded. This makes the neutral light always be on. I was wondering if anyone could help me find a way to make my neutral and reverse lights work properly again. If i am not mistaken, the switches in side the case create a ground, thus letting the lights come on.Would it be possible to do some extra wiring to make that system work correctly while still allowing the cdi to keep it's ground? I am not worried about having a proper neutral safety, i just want the lights on the dash to work right. My starter is not wired up (wires cut to the starter button and missing the solenoid) so i am not worried about that yet either.
Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, 225DX, trx300
