Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 91
Thread: 1985 200x starting issues.
  1. #31
    Mar 2020
    Georgia
    86
    Ok I set it to .012 nothing different I don’t think it is getting enough fuel for it to start now cause it barely wants to start and I give it throttle it will die any ideas? The float is supposed to be at .55 inches I think I have it correct but I could be wrong.
  2. #32
    Apr 2012
    USA
    4,114
  3. #33
    Mar 2020
    Georgia
    86
    Ok now what is happening is I turn the idle speed thing all the way out and it will want to start but I can move it in a half a turn in and it won’t wanna start. any ideas, Is it to lean or to rich? I have the air box hose thing on it too.
  4. #34
    Apr 2012
    USA
    4,114
    You can test if it's too lean by choking it a little with the idle screw in more. If it's easier, then it's probably closer to the ideal mix. Also engine temp effects tuning, that's the whole point of a choke, it's only for cold starts.
  5. #35
    Mar 2020
    Georgia
    86
    I done that and it didn’t want to start but when I went back it wanted to start again. Could it be too rich?
  6. #36
    Slidell, LA
    4,737
    Quote Originally Posted by Atc 200x 1985 View Post
    Ok, sorry I am joining the party late.....there is a lot of pages here but not a lot of progress.
    1. Do you have a blue spark?
    2. Do you have fuel in the float bowl?
    3. Do you have any clogs in the air intake?
  7. #37
    Mar 2020
    Georgia
    86
    I have blue spark, I am getting fuel to the float bowl but I don’t know if I am getting enough, and I do not have any clogs in the air intake.
  8. #38
    Nov 2019
    Florida
    1,044
    If you have spark and fuel
    than its either compression or timing
    I bet the timing is out set TDC, check valves Better to be a little loose than to tight at TDC, put in a brand new NGK plug.
    If that doesn't light it off than you have low or no compression.
    MrC.
  9. #39
    Mar 2020
    Georgia
    86
    Ok I’ll try all that it is probably out of timing cause I could never set it on point. Is there a special link on the cam chain that is supposed to be on the o on the cam sprocket? I rebuilt the engine but didn’t Hone the cylinder should I have done that?
  10. #40
    Slidell, LA
    4,737
    you put a new piston in but you didn't bore or hone the cylinder? There is no special link on the cam chain. There is a thread on 3 wheeler world that tells you how to set the timing.
  11. #41
    Mar 2020
    Georgia
    86
    no Boring or honing was done when I installed the new piston. should I have honed it? Sorry I should’ve made that clearer.
  12. #42
    Mar 2020
    Georgia
    86
    I have good news it starts again but as soon as I give it throttle it will die to rich or to lean?
  13. #43
    Apr 2012
    USA
    4,114
  14. #44
    Mar 2020
    Georgia
    86
    Sure how would I do that do I copy the link of the video? Another thing is it still hard starts but I have to put fuel in the spark plug hole then it would start.
  15. #45
    Apr 2012
    USA
    4,114
    Yea, just copying the url of the video and pasting here would be good enough for us to see it. Youtube, facebook, etc should work for uploading, just make sure the video is marked for public view.
