Results 1 to 6 of 6
Thread: What is this called? On recoil assembly, small plastic clip
    Dec 2009
    Pensacola FL area
    3
    1984 Big Red 200ES
    There is a little splined shaft that comes out through the cover for the recoil assembly (about 5pm location) it had a little white plastic clip on it being retained with a C clip. The plastic piece broke and I can’t find it on any schematics I don’t even know what it does?
    Any help??Click image for larger version.
    Dec 2009
    Pensacola FL area
    3
    Attachment 261995
    This is what the clip came off of
    6,726
    Dec 2009
    Pensacola FL area
    3
    Thats awesome! thanks for the quick reply! any idea how that works?? I cant see how it indicates Neutral? is there some sort of magnet in the plastic? what senses Nuetral?
    2,534
    The shaft that it mounts on rotates when you shift gears. When the indicator is in the proper position, it points at the "N" beside the shaft. It rotates away from the "N" when you shift.
    Oct 2016
    Vancleave, ms
    That’s the gear indicator. Goes on the little shaft sticking out below the shaft for the shifter. There’s an N and in neutral it should be pointing toward the N.
