On my 350x carb I知 wondering what to set the slide height to. When I hit the throttle, how much play should there be before the slide lifts is what I知 wondering. Any info is helpful.
There should always be a little free play in the throttle when closed, not much, just a tad. It is very important that the slide can close all the way with no tension left on the cable.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
Just for everyone to know, I found it in the manual. It is called throttle valve synchronization. It can be found on 4-10 in the service manual. You should adjust the slotted linkage to where the slide moves exactly with the butterfly valve. I hope this helps everyone as I have found that there is 0 information on this adjustment to your carburetor
... except for in the main source of this type of information: the service manual.
(sorry, just being a smarta$$) Nice info!
- Frank
1984 200ES Big Red
1985 350X (x2)
1986 350X
1986 250SX
1984 Auto-X
1984 ATC70
1985 ATC70
no problem
