Thread: 350x carb slide adjustment
    Dec 2019
    Jackson MI, USA
    17
    On my 350x carb I知 wondering what to set the slide height to. When I hit the throttle, how much play should there be before the slide lifts is what I知 wondering. Any info is helpful.
    devore,ca
    903
    There should always be a little free play in the throttle when closed, not much, just a tad. It is very important that the slide can close all the way with no tension left on the cable.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Dec 2019
    Jackson MI, USA
    17
    Just for everyone to know, I found it in the manual. It is called throttle valve synchronization. It can be found on 4-10 in the service manual. You should adjust the slotted linkage to where the slide moves exactly with the butterfly valve. I hope this helps everyone as I have found that there is 0 information on this adjustment to your carburetor
    May 2009
    S.E. Michigan
    1,160
    Quote Originally Posted by Fixer_Upper View Post
    ... except for in the main source of this type of information: the service manual.
    (sorry, just being a smarta$$) Nice info!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Dec 2019
    Jackson MI, USA
    17
    �� no problem
