Just ran a shop in PEX. Easy to plumb and should be fine for most compressor output.
Parents were in upholstery and used black iron. They only ran about 90psi because it was mainly staple guns and not many air tools. Uncle was a plumber and he put that in mid-80s and never had problems with it. Obviously shut down air compressor down each night. Before weekend we emptied the water separator and then took the furthest away drop and attached an air nozzle and held it open until tank was empty.
Not great pics
4 reels on this wall with slope to legs for blowing out. Take offs for the reels go up and over, first
Drops are easier to see in machine shop, lines are sloped to right of pic here
Woodshop, air is behind the pvc dust system. You can only see the reel here. I think there are 6 drops in that room
I think I was at around 2k installed, clearly a lot cheaper DIY, some walls were 50-60’ runs, so a good deal of copper and the elbows in the drops and fittings add up. I am very happy
We originally planned on a 2” loop threw out the shop with 1” drops so we would have enough air for the impacts but now we never use the air impacts cause the battery one work so good. I will have to go get some good measurements and get some prices with 3/4 and 1 copper. I was thinking of using one of those air line kits you can find but they seem like the get you on the adapters/fittings to hook them all up
I never use my air impacts now either.
Descale
Inflate
Blow/blast
Sandblast
Yea that’s about my biggest air consumers too
Trikes
1970/71 US 90 (Aquarius Blue)
1972/73 US 90 Green
1977 ATC 90 w/83 110 motor (Fugly)
1982 ATC 70
1983 ATC 70 (Ladybug)
1973 ATC 70
TF 2015
Other
1983 Honda Z50
1978 Honda XL75
Yea we have a sandblaster too. That really shows you how well your air dryer works or don’t work.
Milton air fittings are absolutely top notch. I've been using them for years myself. They make the only A-M-T fitting I've ever used that doesn't suck. After the first one I bought probably 15 years ago, I've always put them on everything I bought from that point forward. Nothing chaps my arse more than finding out the air tool you just dug out doesn't fit the line. Or if I'm away somewhere using the air from the truck and I borrow a tool from someone, I don't need to worry about what kind of fitting is on there.
Before someone go outfit their entire shop with these on my word, buy just one and try it. I recommended them to a guy I know in the past and he was bent because he didn't like them. In my defense, this guy would have a hard time changing a belt and buys actual tools from Harbor Freight, so he doesn't have much of a gauge for these things. I think they're the tits.
The Milton Hi-Flow V style also fit the M and A style plugs but you'll lose the hi-Flow capability.
V style couplers and plugs offer a maximum pressure of 300 PSI and air flow of 74 SCFM.
M style couplers a max of 300 PSI and airflow of 40 SCFM.
A style couplers a max of 300PSI and airflow of 35 SCFM
AMT style couplers a max of 300PSI and airflow of 42 SCFM
The V style offers a good increase on SCFM over the others
I've swapped over most, if not all of my tools to the type V and I keep a few spare type V connectors in my toolbox for new tool purchases or if I damage one.
The bonus, for me at least, is if someone wants to borrow an air tool I just tell them mine won't match their fittings. I never used to mind borrowing out tools but I'm old and crotchety now and over the years I've grown tired of maintaining a "borrowed tool" list on the door of my cabinet and hunting down "I'll bring it right back" tools and tools damaged by people using them incorrectly.
I also give my connections a little dab of oil to keep the o ring lubed and things working smoothly.
