Thread: Aftermarket carb won’t work on oem intake on 1985 atc 70
    Mar 2020
    Eastern Ky
    4
    I bought what was supposed to be the same size carb but when came in carb was to big for intake. Are there any aftermarket carbs on eBay for fit the oem intake?
    Australia
    580
    I tried 2 oem carbs on my 70 and they didn’t seem to work even with a carb kit with them! I tried to adjust but they always seemed to have a flat spot and didn’t run right! Slapped on this carb from eBay from China and no problems at all for some reason. Runs good and no problems for months.
    Mar 2020
    Eastern Ky
    4
    My intake is to small for the aftermarket carbs, does this carb bolt up to a oem intake
    devore,ca
    1,015
    I run the china carbs on mine also. No problem.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Mar 2020
    Eastern Ky
    4
    Is it a direct bolt up to intake, the carbs I have don’t line up
    Australia
    580
    Quote Originally Posted by slonerzr18 View Post
    Yes bolts up to the oem intake
    az
    1,949
    can you run the stock air cleaner with that carb?
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    1982? 185s
