I bought what was supposed to be the same size carb but when came in carb was to big for intake. Are there any aftermarket carbs on eBay for fit the oem intake?
I tried 2 oem carbs on my 70 and they didn’t seem to work even with a carb kit with them! I tried to adjust but they always seemed to have a flat spot and didn’t run right! Slapped on this carb from eBay from China and no problems at all for some reason. Runs good and no problems for months.
My intake is to small for the aftermarket carbs, does this carb bolt up to a oem intake
I run the china carbs on mine also. No problem.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
Is it a direct bolt up to intake, the carbs I have don’t line up
can you run the stock air cleaner with that carb?
81 185s
82 185s with 85 200s motor
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
projects coming along
85 200s
81 suspended 185s (can't believe I came across 2)
1982? 185s
