Ok, guys this one is for me, I have flipped so many this year its time to do one for me. I have always wanted an X and I think I found a great one to save.
I got it to run, but barley, it smoked more than Dennis Leary in the 90's I have to leave the shop and let it air out.
So here we go, Its not a restoration or a Custom, just build it back to driver condition.
may be a few power adders along the way.
So today was the day, I pulled the engine and lost my cherry while I split my first case. I must admit I am a bit nervous about it.
The compression was 92 psi, its smoked terrible and the kickstarter slipped every other kick. so I figured to start there, split the case, back cut the kicker gears and replace the coil spring, Hone (not bore if possible) and D.I.D. timing chain and add a new 10.25 wiesco piston and ring pack, Keep the Super Trapp exhaust.
I have book manual
Q. I have split the case, The left side is off, in these pictures, do I have to remove the gearset and shift forks to pull out the kickstart gears/shaft or do I have to flip it over and it comes out the right side of the case? The book is hard to tell.
Thanks.
MrC.
