Results 1 to 10 of 10
Thread: Funny Suzuki
    Hanston, Kansas
    126
    Funny Suzuki
    Decided to share this funky, compulsive, and silly project I've been working on. It all started out a year or two ago cruising facebook when I came across this ugly bike I'd never heard of. It was close, mostly complete, and only $100 (obligated to buy). Drug it home and started researching and gathering parts. What I had purchased was a 1974ish Suzuki RV90. Ended up with a decent pile of parts and began to get serious about restoring this thing. Well life gets in the way with a move and job change. The good thing is I moved into a place with a little garage. So after the move I wanted to get started. After much consideration I picked up another machine in way better condition, titled, and ready to go. It slowly snow balled into where it currently sits. I put alot of NOS parts and time into getting her fully operational. No drips, runs crisp, and everything works. Plan to enjoy it around town this summer and just wanted to share! I could turn this post into a full build thread if you guys are that bored haha Also working on putting together a video if you're all interested.
    Thanks,
    Drew
    Attached Thumbnails Attached Thumbnails RV90 1.jpg   RV90 2 (2).jpg   RV90 3.jpg
    Jun 2015
    stonecreek ohio usa
    654
    That's pretty cool. Are those rims painted or anodized?
    Hanston, Kansas
    126
    Jun 2015
    stonecreek ohio usa
    654
    Cool!! I'd hang on to that thing.
    I like it the tires and wheels give it a racy look. Did you powder coat the wheels or just paint them?
    2,196
    AKA - VanVan
    I rode on of the new 200s a couple years ago. Totally different, but similar looking.
    Does yours still have the tire pump on the frame? I thought that was a neat touch.
    Part #25
    https://www.bikebandit.com/oem-parts...39639sch282742
    fingerlakesny
    2,835
    Cool bike. I have one I'm trying 2 get the back wheel off...do you or anyone know how it comes off . I'm turning the right side end and got the nuts off other side but the shaft won't come out... Looks like a smaller inside. Shaft that spins ?
    250r dust runner
    Hanston, Kansas
    126
    This will be the second time trying to respond to this thread haha. Thank you all so much for the comments. This thing has been a blast. I might have covered it in the video I'm not sure, but the wheels are painted. I wire brushed them down to bare metal and sanded everything smooth. Initially I was going to paint them a stockish silver but later decided on the gold. I used high temp VHT engine paint and think it turned out nice. Neither one of my RV's came with an air pump unfortunately! There will be more to come with this thing and I plan to continue updating this thread!
    Dustrunner, it sounds like a stuck axle to me. To remove the rear wheel all that is required is to remove the axle, undo the brake stay and control rod, remove brake side axle spacer and drum, and you should be able to remove the wheel/hub. If there isn't enough clearance just remove the larger nut on the sprocket side (this allows the second half of the cushion drive to be removed from the swingarm) and you're all set. If this wasn't clear we can PM and get it sorted. Check out the pictures (hopefully it helps!)
    2,196
    I found a picture I took from a motorcycle show. Forgot I had this until yesterday. It's a RV125 and a RV90 in the background. Only the second RV125 I've seen in person.
    Nov 2014
    GA
    11
    That's a cool bike! I dig the fat tires.
