Results 1 to 15 of 59
Thread: Random information thread
    Nov 2015
    Davenport iowa
    1,144
    The Bar-Headed geese can fly at a 30,000 foot elevation and fly 50mph, double that speed with a tailwind.
    1974 original 90 X 2
    1974 Original 70.
    Oh I like this thread already.
    Holding the throttle wide open clears a flooded engine. I feel this should be common knowledge, but I see people give up on starting flooded engines all the time simply because they don't know enough to keep the throttle open. I see professionals on TV unaware of this procedure as well. Flooded engines start when you hold the throttle wide open. I've showed people this and then watched them NOT do it under an hour later. People refuse to believe it works for some reason. Two weeks ago I saw someone advising the guy with the flooded engine to "Remove the spark plug and flip the machine upside-down, then crank it over with the plug out." FFS... Just last week I watched a two stroke drag racer forfeit his race because he couldn't get his bike started. To make things worse, a second person came over and cupped his hands over the carburetor horns only serving to flood the engine even more. I almost threw a chair through the TV.
    Arkansas
    2,210
    Dihydrogen Monoxide is colorless, odorless, and tasteless.
    It has been used by interogators to torture and elcitite information from prisoners. It's approved by the FDA as a food and beverage ingredient, and is so widely used, there's a 100% chance it's in your body and impossible to remove without causing death.
    Nov 2019
    Florida
    1,044
    I hate to break it to you "King" but the gas in my body is not odorless, or tasteless, and at times its not colorless either,
    it mostly stinks, taste like old eggs and makes my shorts brown.
    Just ask the wife and youngen'
    MrC.
    Scootertrash's Avatar
    In the sticks
    4,628
    Quote Originally Posted by MrConcdid View Post
    MrC.
    That doesn't sound like Dihydrogen Monoxide to me
    Mexico
    9,012
    If your ATV tire goes flat and you have no other means to fill it, you can simply elevate the tire, remove and replace the valve stem and you will have approximately 2 pounds of air pressure in the tire depending on the elevation you were at at the time you did this.
    The Open Road
    4,729
    Dihydrogen Monoxide is colorless, odorless, and tasteless....
    In most cases, yes, but I had some out of the tap in St. Petersburg Florida that was a wee sulfuric
    And by "wee", I mean "alot"
    Arkansas
    2,210
    Hydrogen sulfide is a colorless gas.
    Dihydrogen Monoxide is the universal solvent.
    Arkansas
    2,210
    When it's summer in North America, it's winter in South America.
    Some sort of blower or supercharger is a requirement for any two stroke diesel engine, however it does not provide a boosted intake charge. Therefore, a two stroke diesel engine with a blower only is known as naturally aspirated, and only those which include a turbo are boosted. The turbo cannot be used on it's own in place of the blower.
    Arkansas
    2,210
    The ol' 6-71 roots blower. I think one of those made an appearance in the final scene of the Fast & Furry Us, gay porn film.
    For the love of Pete, nobody Google that movie title, I just made it up and hope it doesn't actually exist.
    Nov 2015
    Davenport iowa
    1,144
    The world’s largest truck stop is owned by the Moon family and restores all of their own antique trucks on site.
    1974 Original 70.
    In the sticks
    4,628
    Sorry, I had to...
    I found this which would actually make it the true original since it was made in 1949
    https://en.wikipedia.org/wiki/Fast_and_Furry-ous
    No glaringly obvious porn though. Mostly.
    Nov 2015
    Davenport iowa
    1,144
    If I didn’t know better Scooter I would have thought that was a reference to the MOON family, or maybe you’re that good to reference two post with one clip :
    1974 Original 70.
    Mexico
    9,012
    Contrary to popular belief the Coriolis force isn't strong enough to change direction that the water in a toilet bowl spins when flushed, so depending on the design of the loo the water can swirl the same direction as it does in the Northern hemisphere..... winter or summer.
