Page 3 of 3 FirstFirst 1 2 3
Results 31 to 43 of 43
Thread: 81 ATC250r Hybrid Build
  1. #31
    Cold Lake, Alberta, Canada
    3,001
    That is going to look like one slick machine! Keep posting......
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    1978 Honda XL75
  2. #32
    Apr 2020
    New Zealand
    81
    Magura slave is a 0120653.
    Few more pics of mocking up the mirrored 450R stella swingarm, fabricating a bracket for the linkage to run off the rear engine bracket.
    CNC fork to convert the hill shooter from eye to fork. Intake on the way, along with front wheel spacers and plastics, think I’m done ordering parts now.
  3. #33
    Apr 2020
    New Zealand
    81
    Here’s the fabricated bracket for the lower linkage. I was going to CNC it but the cost came back way too high. Anyway, this allows me to fine tune the placement with the slotted mounting hole so I can play with the right amount of angle.
    With this, and the shock foot it should work pretty well.
    Not sure on the swingarm shade yet, might go less flat.
    Axle end of the linkage is on it’s way, lowering link so I can set the geometry.
    Next is getting the swingarm into the right location, need to surface grind the outer faces 4-6mm on the left, 2mm on the right for clearance and to line up the offset front sprocket.
    After that it’s making up the spacers for between the swingarm and engine mount.
  4. #34
    Apr 2020
    New Zealand
    81
    Little bit more done. Mainly the pipe.
  5. #35
    Apr 2020
    New Zealand
    81
    And a bit more, waiting on a few parts to come in this week and hopefully it’ll be on the ground at the end of it.
    Intake fitted thanks to Valley Motorsports, 38mm air Stryker and uni filter.
    Fitted the swingarm to get spacers sized up and locked up the linkage. Think it’ll work. Might need to for a shorter axle side linkage.
  6. #36
    Apr 2020
    New Zealand
    81
    On the ground and fired up for the first heat cycle.
  7. #37
    Apr 2020
    New Zealand
    81
    Update. Waiting for plastics, Brembo rear caliper and sprocket guards - seat being done right now.
    After that decals.
  8. #38
    Mar 2020
    Palestine, AR
    356
    That paint looks awesome. I wish I had the skills.
  9. #39
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    Quote Originally Posted by patriot1 View Post
    Same . . . great job
    Jason
  10. #40
    Apr 2020
    New Zealand
    81
    Rattle can - just have to make sure you get everything clean. It’s really easy if it’s prepped well.
  11. #41
    Apr 2020
    New Zealand
    81
    And finished this one finally too, runs really well, a lot of fun to ride.
  12. #42
    Las Vegas, NV.
    2,452
    It came out very nice! I like the finished product. Now go enjoy it!
  13. #43
    jasong_10's Avatar
    Apr 2020
    Croghan, New York
    420
    Still can't get over how nice that red is, great work.
    Jason
