Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
Thread: 81 ATC250r Hybrid Build
    Apr 2020
    New Zealand
    81
    Picked this basket case up from a local guy along with the 200x. I don’t have a lot of photos from before hand but it’s fair to say it’s in really poor state.
    Engine had a cracked case on the clutch adjuster side.
    Came with two back ends. Both had been hacked up and fitted with crappy car disc brake setups.
    Had the 200x front end on it as well.
    Plan for this one is to:
    Repair the frame
    Fit a Trx450r back end
    Stock front end with progressives
    Stock motor +1 oversize
    DG exhaust
    Possibly going to experiment with an electronic shock
    New plastics
    Apr 2020
    New Zealand
    81
    Started ripping it apart, engine is in bits at the moment, waiting on my piston to come so I can have the cylinder bored before going out to Vapor blasting.
    Ground off all the extra brackets and crap that had been fitted to the frame.
    Apr 2020
    New Zealand
    81
    Found a complete 04 Trx450r back end and mocked it up to give to the fabricator.
    I’ll be using the back brake and pedal setup as well.
    At the moment the plan is to cut back into the main brace at the engine side to allow the swingarm to clear the back of the engine.
    Also relocate the caliper stopper to the other side and fabricate a new chain guard as it’s on the other side.
    The bearing carrier will go in backwards which should be fine. Everything switches over easy enough.
    If the back cut causes cracking I’ll order a chromoly 450r swingarm from stellar or someone and ask them to clearance for the engine.
    Few photos show the issue.
    Also need to weld in a new frame cross brace below and behind the current one to allow the linkage to attach.
    Last just need to machine the bushes to fit with the old swingarm to engine bracket.
    Shock will sit a bit further forward on the frame to make the geometry work out.
    Connecticut
    1,605
    Good start on your hybrid
    Apr 2020
    New Zealand
    81
    Decided to go straight to the custom mild arch swinger from Stellar, reasoning being that if I made the mods to the frame for a custom TRX450R swinger I’d be stuck with having to cut and weld each time I need to replace.
    Ordered some bits, and sending the engine out for Vapor blasting this week.
    Found a 300r kit on ebay, which is now over at CT racing getting things sorted before heading my way. Needs a sleeve and a re-dome plus piston.
    Picked up a durablue 2+2 for the backend for $200 on ebay, and a LSR billet carrier for $80.
    Sent from my iPad using Tapatalk Pro
    Apr 2020
    New Zealand
    81
    Built my own Vapor blaster in the end. And settled on a colour. Building now.
    Apr 2020
    New Zealand
    81
    Build list:
    Stella swingarm, 450r with sides reversed (if he has time)
    Dura blue rear axle, 450r carrier and brakes
    Original front shocks
    Hill climber rear
    Standard bottom end with 300 kit
    Clake two lever
    Brake pedal delete
    Keihin carb upgrade
    Paint and panel, though mainly paint. Keeping it fairly raw.
    wild200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    196
    looks good. following.
    Apr 2020
    New Zealand
    81
    Thanks, bit more progress today. Paint is duplicolor metalcast anodizing spray. It’s a real pain in the ass to apply, has to go on really thin.
    Worked out a process that works for me in case anyone else is suffering through using it.
    Blast parts back to metal
    Heat part to 75C
    Apply 2 light base primer coats followed by two wet, 5 mins in between
    Back to 75C
    Apply 4-5 light colour coats 5 mins apart
    Back to 75
    Apply 4-5 more colour coats 5 mins apart
    Bake at 105C for 24 hours
    Colour changes with more application so consistency is key. I like the finish, and I’m going to use it on the frame as well. For that I’ll blast it, light base coat so I can still see the frame patina, and then relatively light coats of colour. Should be able to see the patina through the coating.
    My shock has D/G stamped on it, were they made by DG?
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    That red is awesome
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    356
    I am ready to see this finished. Very interesting build
    Apr 2020
    New Zealand
    81
    Bit more done.
    Apr 2020
    New Zealand
    81
    How do you get this drum stopper on? Any tips? Spring is a pain.
    Jan 2015
    MB, Canada
    64
    That bottom roller is a pain in the ass. Just keep fighting it carefully. You'll win. I usually use a flat head screwdriver and a pick set. No to mention a lot of choice vocabulary. Just make sure the spring is sitting properly on the bottom collar or when you put the top roller on, it won't fit properly on the post. Honda used this roller detent system on a lot of their earlier 2 strokes.
    Apr 2020
    New Zealand
    81
    After many a choice word I managed to get it on. Then realised I’d missed a washer in the trans. Easier the second time around.
    Just waiting on my spec bolt kit now.
    Frame is next, just need to finish up the welding and get it painted up.
