Results 1 to 11 of 11
Thread: Three bond type??
    Three bond type??
    I forget which 3 bond we all use, my enormously tube finally went bad. Of course I didn't look at the tube before I tossed it.
    Valve covers and center cases is the application
    Was it 1124 we all use??
    I guess I never realized they had so many formulas. So, while we're having this conversation, do you guys use any other types of Three bond and what's the application??
    Thank you!!
    Sent from my SM-N960U using Tapatalk
    6,725
    I only use Honda bond HT , the HT is for high temperature .
    I’m sure you know , prep is everything with case glue . Never had it fail .
    Nov 2015
    Davenport iowa
    1,144
    Honda bond, Yama bond, 3 bond, I thought they were all the same
    1974 original 90 X 2
    1974 Original 70.
    Slidell, LA
    4,737
    I only use 1211 3 bond.
    I bought two types of Honda bond because they're for two situations. I don't exactly recall, but one was for gaskets the other for surfaces with no gasket, or something like that. You can read the descriptions on Partzilla if you'd like.
    Quote Originally Posted by DAM shop View Post
    There were at LEAST 6 kinds I found yesterday...
    Yes sir, I do pretty good, can't recall any leaks with parts that I've put together in the past few years.
    I wonder if Zilla has a part number...
    sixpackrt's Avatar
    sixpackrt is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    Pittston,Pa
    184
    Scootertrash's Avatar
    In the sticks
    4,628
    Bond. James Bond.
    Mexico
    9,010
    Bond. James Bond.
    That’s European spec for Jaguars, Aston Martins, Healy’s, etc.
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    Whatever the white 3 Bond is.
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
