Results 1 to 15 of 63
Thread: 86 200x Build
    Apr 2020
    New Zealand
    81
    86 200x Build
    Picked this one up locally, it’s mainly complete but missing the carb, seat and rear fender. Got it with a 250r, which had the 200x front end fitted.
    I’d like to increase the bore to 251, add an oil cooler and megacycle cam, port the head etc.
    Wondering if anyone knows if the megacycle needle bearing cam works with the 86? Or only the previous generation. I know the 86 had a bearing so possibly it’s not needed.
    They don’t seem to have an email address, makes it a bit harder to contact them from overseas.
    Trying to keep this one looking stock.
    Anyone have a 86 seat for sale?
    Apr 2020
    New Zealand
    81
    86 200x Build
    Pretty much decided to get the 251 kit from MD for this build - anyone running this?
    Got the engine torn down and ready for Vapor blasting this week. Looks mint inside, seems to be on second OS bore.
    Not sure about that green engine oil though....
    In 86/87 Honda used ball bearings on your cam, the heads are almost always reusable, you will be buying a cam and one bearing comes on it after they press on the sprocket.
    I have a new oil pump chain if you need one, lots of used but good motor parts too.
    I've amassed 3 take out and 10 used 86/87 motors
    Apr 2020
    New Zealand
    81
    Thanks, farrrr out, this is only the 2nd 200x I’ve seen in NZ at all.
    Quote Originally Posted by anon3 View Post
    You're lucky to have it!!
    Nov 2019
    Florida
    1,047
    I just got mine back together this morning, My first time splitting the case, she started on the second kick, I got lucky have rode it off and on all day.
    Worst part was scraping all the old gaskets off- yuck.
    Otherwise it went very smoothly, I hope your does too.
    here it is today with the rest.
    Mrc.
    Apr 2020
    New Zealand
    81
    Quote Originally Posted by MrConcdid View Post
    Mrc.
    Awesome. Yea the gaskets were really on there. CRC gasket remover for the win.
    That stuff peels paint really really well.
    Apr 2020
    New Zealand
    81
    Finally started this build too. Matte and gloss black for the cases. L
    wild200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    196
    nice so far anon. The second 200x you have ever seen is an 86??? not bad. there are so many more from years previous..
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    Looks great so far. Is that some kind of drying cabinet, or an oven?
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
    Apr 2020
    New Zealand
    81
    Quote Originally Posted by wild200x View Post
    Yea, they are super rare over here. Trying to keep this build relatively respectful to the original, just playing with gloss levels and possibly change the blue to cobalt blue.
    Apr 2020
    New Zealand
    81
    Quote Originally Posted by jasong_10 View Post
    It’s an environmental chamber at my lab. Really handy for stuff like this.
    Using duplicolor engine enamel on this one and I’ve found heating to 75C before coating makes the paint stick really well and speeds up recoat time.
    Prime and then back in, out to paint. Lots of thinish coats. After coating I find the flat works better to go straight into another chamber at 105C to dry and bake. Gloss seems to finish nicer by air drying and then baking at 105.
    If you air dry the flat it seems to develop a semi gloss kind of look.
    Bit more done today. Cases are all done, just baking in. Red bits are the 250r.
    May 2009
    S.E. Michigan
    1,251
    That red look gorgeous! Nice work.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    jasong_10's Avatar
    Apr 2020
    Croghan, New York
    420
    That looks great, you'd never know it was .
    Jason
    Apr 2020
    New Zealand
    81
    Nearly done with painting bits and pieces. Next job is get that f@cking swingarm off the frame.
