Results 1 to 8 of 8
Thread: 1986 350x clutch problems, need help.
    Nov 2019
    Elk Ridge, Utah, United States
    5
    I purchased a 1986 350x 6 months ago and slowly had to buy the parts necessary to get it running. During that process I put in new clutch plates, discs, and springs. Today I fired it up for the first time and noticed that the engine would shift into gear fine but would only crawl forward no matter how much gas I gave it. The other strange thing I noticed is even when it's in gear I can still push the bike forward and back. I'm not sure what could be causing this. Side note: the external oil line had a crack in it and my attempt to seal it actually blocked the line. Not sure if this would cause clutch issues. I will need to replace that line. Any help is appreciated
    Apr 2014
    Edmond, KS
    2,537
    Is your clutch cable adjusted properly? It sounds like your clutch isn't fully releasing.
    Aug 2005
    CT
    206
    Same thing happened to me but it was over 10 years ago and I can't remember exactly what caused it (I think my pressure plate was broken) but I do know it was obvious what it was when I disassembled it.
    I think I have a pressure plate if you need one, just let me know.
    Mexico
    9,012
    Does your clutch lever have play in it?
    Dec 2019
    Long Island
    85
    Most definitely seems like the clutch is not engaging for some reason.
    In the garage
    2007 Yamaha Tri-Z 450
    2017 YZ 250F
    2003 XR100 (son's)
    2005 Raptor 350 (other son's)
    Gone but not forgotten
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    Jun 2013
    Oceanside, CA.
    610
    External oil line has nothing to do with clutch, but may now have top end cam/rocker arm damage lack of oil. You need to disassemble clutch something is not installed correctly like the shim spacer.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    devore,ca
    1,015
    I had a 350x clutch giving me fits a while back. Turned out the cable was coming apart inside the sheith and not allowing the cable to move inside to return the clutch to the closed position.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    There are so many variables without any of us knowing exactly what you have.
    Just a week ago a guy put an 86 cover on an 85 350X but never mentioned it when everyone was trying to help.
    Another guy had an 86 cable on an 85, there are lots of variables.
    If it's crawling, your clutch is never closing the pack. That can be a spring issue, a plate issue, a thrust washer issue.
    Is the inner hub free of the outer hub when the 4 springs are removed?? That's another issue some people have...
