I recently purchased a 1984 Honda 185S and the pull cord is fully extended. I removed all the bolts to remove the cover only to find it is stuck. It will only separate from the case by about a half inch. I have tried to rotate it, smack it with a rubber mallet and nothing works. It seems that the dogs are stuck or a spring is stuck. Has anyone had any luck removing this or could give me some advise on how to remove this recoil cover? Thanks
