Results 1 to 3 of 3
Thread: Tri Zinger Top End!!
    May 2020
    Peru, IN
    3
    Question Tri Zinger Top End!!
    I just picked up my second trike, an '84 yt60. after tearing into it the cylinder is destroyed and the top end bearing is very worn. not sure how it even ran. I'd like to just order a new top end altogether rather than bore the current cylinder. Anyone know of any good kits?? I've been looking at the melossi 70cc kit for the qt50 peds but idk if it will work with the stock head, jets, and pipe. I've also looked a chinese kits but they scare me. Thanks!
    https://www.treatland.tv/Yamaha-1980...kit-318007.htm
    https://www.ebay.com/itm/Yamaha-Yt60...UAAOSwo4pYL2Ze
    rayatc84's Avatar
    rayatc84 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2010
    France
    194
    I have 2 Zingers with the 70 Malossi kit + high compression head.
    One has a DG pipe and the second OEM pipe, but both have stock carb+jetting+reeds and run very well.
    My nephew has also a Zinger with the 70 Malossi kit + high compression head with OEM pipe+carb+jetting+reeds and it also run very well.
    The upgrade 70 Malossi kit + high compression head + DG pipe really transforms the Zinger.
    Outside of engines with holes that stink, there is no salvation...
    My feedback thread: here!
    Want to see overseas 3wheelers? http://www.passion-atc.com of course!
    YT60 Tri-Zinger, YT70 Tri-Zinger modified, '84 ATC 70, '82 ATC 110, '82 250R, '82 250R modified, '84 250R, '84 480R in build, '85 310R, '86 250R, '87 250ES BigRed, '84 FL250 Odyssey, '85 FL350 Odyssey
    Arkansas
    2,208
    Welcome.
    I've ordered a few things from Treatland. Got their sticker on my tool box lid.
