Thread: Honda 250/triz
    HEAD09's Avatar
    HEAD09 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    NH
    433
    Honda 250/triz
    Hey guys quick question, I acquired some ITP rims that has a bolt pattern of 4+110 With Gecko
    Sand tires on it but I need hubs that’ll fit the tri-Z... So my question is are the splines the same
    as the Honda or any other sport quad? Thx
    Manheim, PA
    5,758
    splines are not the same but if you file honda down some you can change the hardness of the angle and they will bolt on. You need you use a triangle shaped file and do about 10-20 passes thru each spline. This should take you about an hour depending on what year hubs you get as older many be worn a little and newer may not be worn.
    HEAD09's Avatar
    Apr 2006
    NH
    433
    thx for the info...so no other quad will work? thx
    Mexico
    9,011
    As far as I know Banshee and Blaster hubs share the same splines as the Tri-Z.
    HEAD09's Avatar
    Apr 2006
    NH
    433
    i just remembered that there was a interchange parts for the triz on here....duh! and it looks like honda's have what i need(4x110)...dammit! thx for help
    Manheim, PA
    5,758
    blaster and tri-z wheels are the same. Just buy some honda TRX hubs file the splines and put your honda rims on and go ride. I just did this with a blaster, a warrior a banshee.
