Anyone have any tricks to removing inner pinion bearing (just the outer race, rest is gone) from a 250es diff? Have 2 to get out and will have these trikes on the road. Thanks.
Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
You have to remove the wire clip that holds the bearing from moving and then you’ll need a blind bearing puller , the kind with a slide , some times heat is needed .
These are very tricky to get out and if you’ve never done one then your probably better off paying someone that knows how .
I’ve been doing them for over 30+ years and I still find it difficult .
