So I'm in the process of rebuilding an 84 ATC 110. The shifter lever and shaft splines are worn down pretty bad. My options are to possibly try to drill a hole through both and put a bolt through, or replace the shifter shaft and arm. In looking on eBay I did find one but it arrived with messed up splines too...
Are the ATC 200 shifter shafts compatible with the 84 110? I see alot of those on eBay!
Any help appreciated
