Results 1 to 10 of 10
Thread: 350X Front Brake Line Semi-rigid Guard?
    Jul 2002
    El Paso, Texas
    510
    I'm not sure why I haven't done this yet, but what can I use to cover my stainless brake line from the bottom of the fork to bottom of the triple tree? You can see in the pic how it bows out....drives me nuts. Looks crappy, too. Any suggestions?
    Also, what can I use from the guide at the base of the triple tree up to the top of the light guard? Feels like I may need something there, too, or it may correct itself when I add the bottom piece.
    (It's a mess because I just got back from a desert ride!)
    Attached Thumbnails Attached Thumbnails IMG_8147.JPG   IMG_8149.JPG   IMG_8150.JPG
    Honda
    86 350X - Full Restomod
    85 250R - Next for Frame Up
    85 Big Red - Clean Original
    Sulphur Springs,Texas
    1,005
    Here is the brake guide you need for the triple trees.
    https://www.ebay.com/itm/224070247030
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Jul 2002
    El Paso, Texas
    510
    Quote Originally Posted by Aulbaugh View Post
    Thank you! That will help me at the top.
    Does anyone else have an application for the middle?
    Honda
    Las Vegas, NV.
    2,446
    I got 2’ of rigid plastic tubing from my local hardware store. The kind that would be used for a refrigerator water line, but a larger diameter. The tubing’s ID, wasn’t large enough to fit over the plastic coated SS brakeline’s OD, so I slit the tubing lengthwise, wrapped it around the brakeline, then put some clear heat shrink tubing over it to hold it in place. Just get a piece of tubing that’s long enough to go from the forkleg’s brakeline clamp to a few inches above the top brakeline guide. It works like a charm and looks factory.
    Sounds like a easy fix you have any pics ?
    Las Vegas, NV.
    2,446
    Quote Originally Posted by big specht View Post
    Yep. Just trying to figure out how to drag and drop a previously uploaded pic on my iPad.
    Jul 2002
    El Paso, Texas
    510
    Red Rider, great idea!! I used both clear and black heat shrink to stay with my color scheme.
    Attached Thumbnails Attached Thumbnails D3D565F8-BEE2-4DCF-9B68-5EF62D89B51C.jpeg   1E64E738-D480-4B15-AC3C-7397FB807A87.jpeg   5D7DF9FA-D595-4F7F-B3DC-0F702D245CCC.jpeg
    Honda
    Las Vegas, NV.
    2,446
    Kris, it came out awesome. Looks like you will not have anymore cable-flexing issues in that area.
    Jul 2002
    El Paso, Texas
    510
    Thanks man. I appreciate the idea and inspiration!
    Honda
    Las Vegas, NV.
    2,446
    Quote Originally Posted by 350Kris View Post
    You're quite welcome. I try to help out when I can.
