Found this online. Skeptical because it, along with 200x, supposedly applies to wheelers with mechanical brakes?
Sent from my SM-G960U using Tapatalk
china junk-
u.s. sellers buy them in bulk from china for under $8 bucks or most likely less.(pic found in a quick search)
Then usually double the price when they sell em on ebay- you just lucked out and found a seller that wants to rob u blind....
honestly if i were you try to find a rear master off a honda streetbike thats been parted- but do what u like/
but i'd stay clear. Yes i learned the hard way on the china stuff.
shep
Ive run them off YFZ450s and YZ400/426. China stuff may work for awhile but its not hard to rebuild them either. Most time when using different master cylinders you will need a longer clevis. I say do it right the 1st time. However having the fluid parts down closer to the brake will free up some much needed space and not melt from head of the exhaust. It might be ok but normaly when cheap you pay 2-3X in the long run.
Dont even ask about those chineese carbs....they are horribly built once you compair
In the process of rebuilding brakes. Having a tough time getting pistons freed up. Got the rear master cylinder piston to move down but not up. Got the rear caliper out, thanks to the pin for the parking brake. Looking at getting a tool for the front caliper removal, if I can find one that fits in that small hole in the piston. The good news is that the front brake master is operational.
Just a heads up.... the china brake calipers i have no problems with at all, there cheap and seem to work very well.
But just so you or anyone else reading this knows theres someone selling front 200x calipers on ebay for like 80-90 bucks each. They are GY6 scooter calipers that anyone can get alot cheaper than his price. (pic) They bolt on your bracket like stock ones, If u shop around u can sometimes find them for $20.
Fit:83-87 200x front
i think 83-84 250r too (think there caliper is the same)
Oh- the brake pads are junk though, just put better pads in or replace em every 10miles if your lucky to get that much.
just trying to save anyone some $
shep
You can also use a cr80 front brake caliper for the rear also
TPC 450R
