Results 1 to 8 of 8
Thread: Rear tires glued to the rims???
    Jul 2020
    UTAH
    Thumbs up Rear tires glued to the rims???
    Bought a 85 225DR for fun and the tires are shot..big holes in them.
    I have the new tires, but can't break the bead on the old tire to get them off the rim.
    I ended up cutting one because the rubber is trash, and it look like the tire is glued on.
    Has anyone ran into this???
    Help is appreciated!
    Nov 2019
    Florida
    1,044
    yes, there is a tire sealant used when the rims are pitted, be sure and wire wheel it off before you mount your new tire.
    generally a tire machine will break it loose, otherwise by hand its a pain. cut the tire off, cut the steel band of the tire with a 3 inch cut off wheel
    or grinder, careful not to cut the rim. then cold chisel off the rest of it. Then wire wheel or flap disc the rim until smooth, you may need to use a little black
    sealant yourself if the rims are really pitted.
    Old tires were thicker, less likely to conform to the rough surface of the rim, like thinner cheaper tires of today.
    It can be a bear.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    May 2009
    S.E. Michigan
    1,250
    The bead can be very tight... it is almost always VERY tight. I've had the worst time on steel rims. It seems that aluminum rims are easier to break the beads and demount tires. Are you using a bead breaking tool, or something else?
    I've never had a bead glued to the rim. I have had them where the tire spun on the rim and left some rubber on the rim (maybe melted on?).
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Jul 2020
    UTAH
    They don't look to be too pitted from the inside.
    Theyre dirty in there from time spent sitting I assume.
    I'm going with the soapy water, flat head, crowbar method.
    May 2009
    S.E. Michigan
    1,250
    Quote Originally Posted by ewil1478 View Post
    If you're talking about breaking the bead, I don't think that will work. If you mean to get the tire the rest of the way off of the rim once both beads are unseated, ok. I use an actual bead breaker tool and with the difficulty of breaking some, I really doubt you can be successful with a crow bar. The beads on ATV rims/tires is way more aggressive than other wheels/tires (like lawnmowers or trailers) since ATVs operate at such low pressures.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Dec 2019
    Long Island
    85
    I use the cheapo method bead breaker. I have a 2x6 about 36" long with one end concave to conform to the shape of the rim. I put the concave edge right up against the rim along the bead, the other end on the ground then drive my truck up onto the wood nice and slow until the bead pops. Flip it over and do it again. Works like a charm. ��
    In the garage
    2007 Yamaha Tri-Z 450
    2017 YZ 250F
    2003 XR100 (son's)
    2005 Raptor 350 (other son's)
    Gone but not forgotten
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    Manheim, PA
    5,759
    A dealer or any tire shop can change the tire for a few bucks. Get the rim back have it sand blasted an powder coated so the next tire has so thing not to glue its self to.
    I stopped messing with tires to save a few bucks.
    az
    1,949
    stuff is called bead sealer, oreilys carries it. ive used a propane torch on rims to soften up the rubber to break the bead. jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    81 suspended 185s (can't believe I came across 2)
    1982? 185s
