So I have the left side of the engine cover off to try to find why the shifter wouldn’t return to center. Replaced the loose/ broken pin and removed the drum shifter with the little springs and pawls and the lever underneath. When ratcheting from gear to gear the pawls will catch 1 gear on the drum back and forth and then keep ratcheting(because they can’t catch a gear in the mechanism) or I can bump back the shifter and the pawl barely catches the outer drum bowl in the shift drum piece and locks up and won’t move..
It seems I need to line up the shift drum and shifter, or the springs and pawls on my shift drum ratchet piece do not have enough tension?? Everything else looks perfect per the service manual. I’m trying to shift with the cover off and the gearshift lever in. It’s not moving the wheel far enough to engage the next gear other than 1 back and forth
New pawls and springs?? They look fine??
I want to close this up tomorrow if I can
Thanks
