Results 1 to 15 of 60
Thread: Old Manco three wheeler.
    Aug 2020
    Alabama
    40
    I got this old Manco three wheeler given to me. I’m going to fix it up a little and get it back going. One of my problems so far is that I can’t get the front tire off. I can’t get the axle to move but a tiny bit. I thought it would slide out one way or the other. Does anyone have any tips on removing this?
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    Looking at the pics it should slide out left to right, as facing the front of the bike. If itll move some, try working it back and forth, soak it in penetrating oil and see if you cant coax it out.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Aug 2020
    Alabama
    40
    Ok I’ll try that. I have some PB blaster I can try. Thanks for the tip. This thing has been sitting sense 1994.
    Nov 2019
    Florida
    1,044
    She is a beaut Clark!
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Aug 2020
    Alabama
    40
    Quote Originally Posted by MrConcdid View Post
    MrC.
    Lol. She sure is. This thing is actually very simple but it’s been sitting so long I think a lot of parts are kind of stuck.
    Sent from my iPad using Tapatalk
    Nov 2019
    Florida
    1,044
    Prior to all my 3 wheeler craziness, I was building go-carts.
    a $99 harbor freight predator with a 22 mukuni and a torq-a vertor would make that thing scream.
    Looking forward to how you finish it.
    MrC.
    My Addiction
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Aug 2020
    Alabama
    40
    Yeah I’m going to go with the predator 212 just because of how cheap it is. I hope I can figure out the gearing. I’m not sure what sprocket to run on the shaft that turns the gearbox. I’m guessing I can run the same size sprocket that’s on the driven jackshaft for the shaft that turns the rear gearbox and then a chain will tie those two together.
    Nov 2019
    Florida
    1,044
    https://gokartguru.com/images/Go_Kart_Drive_Line.htm
    I use this to get a good ratio or gearing.
    You can change weight, tire, size, gearing and horsepower.
    Good luck
    MrC.
    My Addiction
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Aug 2020
    Alabama
    40
    Got an engine and mount today. I started to put the chain on and it’s a little loose. Anybody used the half links before? The way it is now it’s either to loose or to short. I may have to make a way to pull the engine forward in order to snug up the chain.
    Nov 2019
    Florida
    1,044
    Yes 1/2 links work well. could you drill your mount plate into slots or extend them a 1/2 inch? that might help also. looking good.
    MrC.
    My Addiction
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Arkansas
    2,207
    Avoid a half link if you can. They are physically the weakest type of link you could use. The rest of the chain has straight, flat plates for links. A half link plate has a bend in it.
    Sometimes, they are the only option, but they are never the best option. I'm a Yamaha BW200 owner; I know.
    Don't think this only applies to motor vehicles either, there are actually half link chains available for bicycles. Literally, an entire chain made from half links. I don't know and don't care why, but they exist.
    Aug 2020
    Alabama
    40
    I made some slots in the mounting plate today and the motor slides forward and back. I am able to tighten the chain now. I think everything in straight. It looks that way when I get back and look down the chain. I think I’m ready to fire it up now. Still need back tire though.
    Nov 2019
    Florida
    1,044
    Glad the slot idea worked out.
    I will blame you, (and carsandcameras) I have wanted to build a motorcycle engine driven go-cart, literally my whole life.
    Today, I pulled down my vintage dingo frame, this is going to happen.
    YOUR FAULT!
    200e high/low, electric start Dingo.
    Keep up the good work
    MrC.
    My Addiction
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Aug 2020
    Alabama
    40
    YOUR FAULT!
    MrC.
    Lol. That’s awesome. Glad I could inspire you. I have been watching carsandcameras also. And red beards garage. I wish I had more money to do these type of projects. I would buy more junk. Lol. I want to put a 212 in an old dirt bike next.
    Apr 2012
    USA
    4,114
    I'm slowly collecting and building a database of tech info, if you wouldn't mind, shoot me a pm of the frame number and engine number (if stock) and I'll add it to my research. I doubt there's much info on these machines so more info the better.
    Also, not sure what model your machine would be, but here's a site that has a bunch of owner manuals posted.
    https://www.gopowersports.com/go-kar...dels-103-5xxx/
    Either case, good luck with the build, already looking a lot better than you started with.
