Results 1 to 12 of 12
Thread: 85 110. Whats going on here
    Oct 2015
    Chapman KS
    30
    Alright guys, i picked up an 85 110 project. Despite the wrong fenders and tank the engine matches the frame. I got it to run but it was pumping oil out behind the hi/low cover so i assumed the case was cracked and pulled engine. Nothing it broken but the hi/low cover oil drain doesnt line up and the engine number is correct for 85. I thought only 90-110 used this side cover and it is cdi engine cover. Whats going on here? thanks
    1978 ATC 70
    1978 ATC 90
    1984 200 es Big Red
    1984 200x
    1985 250sx
    1985 350x
    Nov 2015
    Davenport iowa
    1,144
    Not sure I understand your post. Hi/lo cover drain doesn’t line up? Are you talking the hi/lo case itself doesn’t line up?
    1974 original 90 X 2
    1974 Original 70.
    Oct 2015
    Chapman KS
    30
    3rd picture. Sorry its sideways. The oil drain dump onto the case instead of into it. The 85 110 center case is lower there then like on a 90. Click image for larger version.
    Vs my 90
ID:	264280Click image for larger version.
    This hi/low case is cdi but doesnt line up to 85 center case at the oil drain above serial #, Is the 85 different from earlier 110? Obviously i need to get a different one just want to verify before hunting so i dont get the same issue as previous owner.
    1978 ATC 70
    1978 ATC 90
    1984 200 es Big Red
    1984 200x
    1985 250sx
    1985 350x
    Jun 2013
    Oceanside, CA.
    610
    Someone was very creative in the parts they used to make this build. Saying that they my have used a stator cover from an earlier model CDI motor. Can you post picture / view of complete side cover.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    Oct 2015
    Chapman KS
    30
    I dont have anything currently im at work but checking part numbers the hi/low case is different on 84-85 from 83 and 82 is not same as 83 so i guess i found my answer? I can post a pic this afternoon.
    1978 ATC 70
    1978 ATC 90
    1984 200 es Big Red
    1984 200x
    1985 250sx
    1985 350x
    Oct 2015
    Chapman KS
    30
    Quote Originally Posted by HairyJR View Post
    Here is a side shot
    1978 ATC 70
    1978 ATC 90
    1984 200 es Big Red
    1984 200x
    1985 250sx
    1985 350x
    Jun 2013
    Oceanside, CA.
    610
    You saying the '84 and '85 are the same part number?
    ’84 YT60
    ’90 LT500 Quadzilla
    Arkansas
    2,208
    Someone sure went to chisel town removing one of those side cover JIS screws.
    Matter of fact, many of them met with Mr. Wedge head.
    Looks like someone thought they were unions.
    Nov 2019
    Florida
    1,044
    I am not very familiar with the 110. But I have a 125m that has a cover alot like that that serves as a high low switch.
    Could that be what was used?
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Arkansas
    2,208
    Quote Originally Posted by MrConcdid View Post
    MrC.
    Unfortunately, in this situation, Honda also used that style sub-transmission on their trail bikes, like the CT90.
    I have no idea what fits what or what different versions look like. I've had a few 110s, but never this problem.
    Could it even be the wrong side cover and the right sub-transmission? It's obvious someone had the side cover off, or at least they really tried to.
    Oct 2015
    Chapman KS
    30
    Thanks for the input. I thought the sub transmission was a 90/110 only thing i didnt realize they used it on trailnbikes also. At any rate im hunting an 84-85 sub trans case now.
    1978 ATC 70
    1978 ATC 90
    1984 200 es Big Red
    1984 200x
    1985 250sx
    1985 350x
    Oct 2015
    Chapman KS
    30
    Update. Did some research and found the issue. As i stated 84-85 are same part # and different than 83 and 82. So hunting by photo for what i needed here is the difference and what I needed for the 85. Early 110 CDI cover, VS 84-85, I think, other than looking at what i need i cant confirm the part # on the case yet. Red circle highlights differences otherwise they are the same as far as i can tell.
Name:	110 case late.jpg
Name:	110 85 cover.jpg
    1978 ATC 70
    1978 ATC 90
    1984 200 es Big Red
    1984 200x
    1985 250sx
    1985 350x
