Well with the change of weather to winter i finally tackled this today, went pretty quick and easy, the hardest part was getting the gasket scraped off the brake housing. All came apart easy as can be, no drama whatsoever, brake drum literally fell off, i greased the splines when i was last in there 10+ years ago, goes to show what some good grease will do. Axle popped right out. Replaced the left seal, the o-ring on the axle and put it all back together, had to do a little cleanup on the brake housing, brake dust buildup, gave the drum a quick cleanup with some 600 grit and hosed down the shoes and drum with brake clean and that was about it. Now no brake squeak, there was brake dust buildup riding around the inside of the brake drum. Pads still look nearly new, drum didn't even have surface rust on it, just gave it some buffing with sandpaper to break off the slight glaze on it.
All in all... Easy as can be. Now hopefully its another 10+ years before i have to take it apart and i forget again!
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
