Results 1 to 7 of 7
Thread: 82 Honda ATC 200 Starting issue
    Feb 2020
    Woodville
    9
    Need some help. My Honda 200e has set up since July and I just tried to start it and nothing happens. Not a click or sound. Checked the wiring harness and made sure all was connected properly. Tested battery and it tested ok. What should I do next? The wiring harness was just replaced and has a new start/kill switch. Any ideas? Thanks in advance.
    Arkansas
    2,210
    Does it have gasoline in it?
    Mexico
    9,012
    Did the engine turn over after you replaced the harness and switch?
    Have you tried jumping your solenoid?
    Feb 2020
    Woodville
    9
    Yes on the gas. Yea it ran and worked fine after I changed the harness out. How do I jump the solenoid?
    Feb 2020
    Woodville
    9
    Ok I used a screwdriver to jump the solenoid. It tried to turn over. So should I go ahead and try a new switch now?
    MN
    3,260
    If its just the start button that's easy to take apart and clean, just pull out the bottom screw and remove the start button from the bottom of the left handlebar control. Then try jumpering the wires in that and see if it cranks, if it does its probably just a dirty start switch, i take them apart and clean them with a brass brush, a little de-oxit spray, and then some dielectric grease and put it back.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Nov 2020
    Baker City Oregon
    3
    Dielectric grease all the connections as well. I also believe its a dirty connection though.
