Well the old Jeep developed a noise in the motor at 32K miles which I wanted to tackle before it threw a rod or destroyed something major. So as most things go, if you start on a project they tend to snowball which this will be on an epic scale. Being 68 years old, the old girl was in need of a thorough going over so I decided I'll do a frame up refurbishment to make it safe, dependable and corrosion free. The good news is that everything worked well up to this point on it and shouldn't need a lot of repairs except for a motor overhaul. Hopefully by end of day today I'll have the tub off and can start on the undercarriage.
Plans right now are to:
-replace all seals and gaskets on the transmission, t-case and front and rear differentials
-have a rad shop go over the radiator
-re-arch the springs and install new shocks and shackles
-replace all the brake flex hoses
-replace the wiring harness with a reproduction one
-replace the windshield and sealing rubber
-replace body mount rubber and anti-squeak strips
-rebuild the master cylinder and go over all brakes
-fresh paint
If you're familiar with US models or Canadian models, they had a semi gloss paint on them from factory. Weeeell I'm not doing that, lol. I've found out that Canada trialed a 3 color camouflage in the late 60's that I will replicate. The purists of the hobby will squeal but hey....it's my jeep!
marks on that weld. I guess the frames were hand welded back then with a stick. The
