My first ATC 110 with CDI ignition. I just put her together with all new seals and gaskets. However, I wasn't sure on the valves.
For timing I use the T mark.
For the valves do I also use the T? Or should I use the F mark?
Also does anyone know what the compression should be? After the rebuild I am getting 146psi. I have read that it should be anywhere from 100-196psi..
